engine coolant
Howdy all. I got the intake manifold gaskets on and everything secure. Now my question is, when adding coolant to the system, where do I bleed the system to ensure coolant goes where it is supposed to?
What year is your Monte? On the 00-07's there is a air bleeder bolt on the T-stat housing you open when the car is running. The coolant and air will belch out, when it's coolant only then your good. But do it a few times for ha ha's.
