| 911monteSS |
Sep 21, 2010 08:36 PM |
Electrical/Computer Problems
Hello I am new to this forum and have an annoying problem. I have a 2001 MC SS with 127000mi. I am the only owner and have maintained the car well. Up to this point of its life, I have had very little problems with the car. Last summer the factory amplifier mounted under the rear deck in the trunk died. I replaced the amp with an after market amp and upgraded the speakers using all the required hardware needed continue to use the factory radio head and wiring harness. Everything worked fine. During the last months, I noticed battery draw down and a couple of times the security light would randomly come on. (I didn't experience the normal security light problems listed in other posts) I figured it was a battery issue and replaced my 4 year old battery. This rectified the situation for a couple days. I started experiencing battery draw down again and then had the electrical system tested. Battery, alternator and starter all passed the diagnostic tests. Shortly after this the random accessory relay located in the driverside fuse panel started clicking. Thinking it was a bad relay I replaced it. Same thing happened. This seemed to be more frequent when the weather was hot and humid. I live in SC so it is always hot and humid so as the problem got worse I took it to the shop. At this time the ignition started sticking and I would have to fuss with the key to get the car started. (Not the same issues as the passlock problems) The mechanic said he believed it maybe a BCM problem but it was obvious the ignition had to be replaced and that may fix the problem. I replaced the ignition but the other problems continued. Do these symptoms seem like a BCM problem or are there other trouble areas I should check.
Sorry for such a long post but I wanted to get all the information about my problem out there at once. Any help that you can provide would be greatly appreciated. Thank you in advance!
Colin
