Egr flow code
Old Nov 25, 2006 | 03:05 PM
96Carlo's Avatar
Default Egr flow code
Engine check light came on the other day . My tech told me it was code 401 egr flow. He said I should clean it out myself to save a few bucks. Any tips to do it right woul be greatly appriciated. Thanks.
Old Nov 25, 2006 | 03:28 PM
wiz kidd's Avatar
Default RE: Egr flow code
when you do get it cleaned, buy an egr valve gasket with the screen (bluestreak aka standard part # is VG57) big fix for those things
make sure it has a screen the one you get, cuz if it doesn't the same thing is going to happen again
Old Nov 26, 2006 | 10:31 AM
85T5MCSS's Avatar
Pull the EGR valve off and clean the tube going towards the back out with a stiff pipe cleaner or engine cleaning brush and the passage going to the intake manifold. U may have to use some carb clean on the brush. When done, vacuum the passages out real good and then reassemble.
Old Nov 26, 2006 | 03:04 PM
fever42's Avatar
egr deleat from zz will solve all problems, also runs better.
[IMG]local://upfiles/99/49C6A270E3044531A9F48A204E331473.jpg[/IMG]
antoniodeMONTECARLOmiller
Apr 22, 2018 10:31 AM
Sliver
FWD Tech Guides '95-'07
Oct 11, 2015 02:52 PM
Dottie
MCF Website Problems & Issues
Sep 7, 2014 10:57 PM
ownedbypugs
Mar 21, 2012 01:08 AM
dustybird3
Feb 5, 2008 08:18 PM
