Dimensions needed
I'm putting the "Monte Carlo" script on the rear fenders, between the door and front of the rear wheel opening. Can anyone provide the placement measurements back from the door and up from the molded lower body line?
Thanks! KC |
RE: Dimensions needed
I'll run out at lunch and take these for you unless someone can beat me to the punch.....
TVW |
Thanks, bought the script and painted it Pewter, should look pretty good against the Laser Blue and Pewter pin stripe.
Here's what I have...
2 3/4" from the contour line up to the bottom to the letters. This area is not where the bottom fairing meets the side of the care. It is the molded contour. 1 3/4" from the edge of the door 2 1/4" from the last SS to the edge of the rear wheel opening. TVW |
Thanks...doing the body side moldings today. The dealer has them painted so will see if they'll pop them on while I'm there. I just used the M/C script, without the S/S, centered it between the door and front of the rear wheel opening. The pewter against the laser blue looks pretty good.
do you have the suppe charged edition of the monte? If so they are the same place for the montecarlo scrip as the one that says supper charged on it.
if you let me know d\if youhave done this yet or not let me know and i will run out and messure mine fo0r ya but i am on in your night time im like 9 hours a head of you if your in the centra\el time zones lol |
