Dash lights on 86 Monte
Old Dec 30, 2015 | 11:00 PM
P-E-Z's Avatar
Default Dash lights on 86 Monte
Hi I problem with just the instrument panel lights (Heater/AC lights works correctly) Sometime the come on some times they don't. Don't is most of the time now. Its not the head light switch it was replaced same problem. Is there any known problem that cause this?
Old Dec 30, 2015 | 11:31 PM
I would first check the harness connection to the instrument panel up under the dash. It could be loose or could have corrosion.
