-   -   Can't get HI beams on? (https://montecarloforum.com/forum/monte-carlo-repair-help-8/cant-get-hi-beams-10699/)
Chris611 Sep 23, 2008 07:33 PM
Hey guys, new the the forum. I have a 2000 Monte Carlo. I can't get the hi beams to go on. I pull back on the turn signal and there is no click or anything. When I pull back, the high beams do come on until I release the lever. At first I had then stuck on HI, but I pulled hard enought to get them back to LO. I pulled the plastic halves off the column and can see the turn signal switch. Is there anything I can do to fix this? Or do I have to replace the switch? Is there a relay someone that turns the HI beams on?
Thanks
Chris
mickey Sep 23, 2008 08:16 PM
RE: Can't get HI beams on?
it is the multi function swtich on the colum not hard to fix or replace.
Chris611 Sep 24, 2008 01:20 PM
I am searching the internet for used multi function switches and I find 2 options. w/cruise and w/o cruise? The car has cruise, but not on the multi function switch (turn signal lever), it's on the steering wheel. So when it asks "w/ or w/o cruise", do they mean the car or the lever?
Chris
Space Sep 24, 2008 02:05 PM
[align=center]Hi Chris,[/align][align=center]I think you need a switch like below,[/align][align=center]I searched for one for a 2000 Monte Carlo & could not find, but it has nothing to do with your cruise control. Do a Search for a AC Delco Turn Signal Switch.[/align][align=center]If you dont find, I will search more later, I have to get back to my studies : (
Good Luck from `Space
http://www2.partstrain.com/store/ima...s/ac-delco.gif
[/align][align=center][/align][align=center][/align][align=center][/align]
2000-2005 Chevrolet
"AC DELCO, TURN SIGNAL SWITCH OEM Design Turn Signal, Headlamp Dimmer, Windshield Wiper And Washer Switch And Lever, A High Quality Direct Replacement Part Providing Exact Fit For Easy Installation And Reliable Operation
[/align][/align][/align][/align]
rysZ34 Sep 24, 2008 04:01 PM
try pushing the multi function switch forward and see if it stays.
Chris611 Sep 25, 2008 09:28 AM
So the "w/cruise" & "w/o cruise" have nothing to do with the switch or wiring? One salavage yard said that the wiring was different even though the cruise control wasn't on the turn signal. I figured when it asked if it was for cruise or not, it was reffering to the lever not on the vehicle. Is the monte even offered without cruise?
Thanks
Chris
