A/C Woes
So on my '99 Z34 the A/C doesn't work. Which is a HUGE problem, except when I want to drive on the highway and don't want the windows down. lol. I'm told that the compressor isn't kicking in at all---could that be just the clutch, or the whole compressor and clutch?
RE: A/C Woes
ORIGINAL: rysZ34 So on my '99 Z34 the A/C doesn't work. Which is a HUGE problem, except when I want to drive on the highway and don't want the windows down. lol. I'm told that the compressor isn't kicking in at all---could that be just the clutch, or the whole compressor and clutch? |
RE: A/C Woes
Thanks for the response, I'll definitely take it in and see!!
RE: A/C Woes
Hey Ryan, one thing ya can do is look at the schrader valves where the A/C is serviced. Sometimes the valves back out a little and will leak out the refrigerant. Look and see if it`s oily in these areas. If so take a schrader valve tool and tighten them.But being it`s not coming on you probably need it evacuated and reserviced to get out the moisture.
RE: A/C Woes
Thanks for the tip! I will probably get it serviced when summer is more near. I appreciate your guys' tips and help!
| All times are GMT -5. The time now is 02:45 AM. |
