| asmart82 |
Feb 14, 2012 10:17 AM |
Brake Pad Replacement Problem .... Ooops!
I was changing out my brake pads yesterday and while depressing the piston, I forgot to remove the cap on the reservoir to release the pressure. Unfortunately, as I was depressing the piston, I heard a pop and saw fluid draining down onto the driveway. When I looked under the hood, there was a fluid leak between where the master cylinder and power booster connect. Any ideas what I might have gotten myself into here? I'm hoping its just a master cylinder replacement as I am not certain what to do with a power booster!
