Blower Motor problems...
The blower motor on my 2001 Monte Carlo wasn't working on 1,2 or 3. One blower motor resistor later and a trip to the chiropractor, I have no blower on 5.
GM use to use a high blower relay but I can't find a listing anywhere. Does anyone know if I have one and where it is? Don't tell me it's under the resistor |
Positions 1, 2, 3 and 4 run through the resistor. Position 5 runs directly to the motor through the relay, so I would check it and/or the control switch.
Edit: I forgot to mention that the relay is located on the blower motor control module. |
Thanks for the info. Fan switch OK but you did get me on the right track. Blown fuse. Teach me to check the easiest thing first. Thanks again
