Bad Ground? Help!
So today I was driving down the freeway in my 2003 Monte Carlo SS with a Turbonetics kit. Anyway, I was going about 70 mph when my car did somewhat of a jump and I think it turned off and back on. I say this because all of my needles dropped on the dash then all my gauges came on. Any idea what this could be? I'm guessing a bad ground somewhere?
Bad ground is possible. Bad grounds cause all kinds of weird electrical anomalies.
Another thought - a faulty ignition switch / circuit. I have an old car that did what you described quite a few times. Turns out one wire on my ignition switch was damaged sometime in the past and was partially broken. If it moved a certain way, the car would just shut down as if I turned it off. Then it would come back to life, sometimes a fraction of a second later, sometimes a couple minutes later. Wiggling the wires coming off the ignition switch and reproducing the problem while sitting in the driveway finally clued me in to the problem source.
TMoney
Apr 9, 2014 09:32 AM
BigPana
27
Jun 24, 2011 11:37 AM
