Antifreeze flush
Yes, each time you refill the radiator use nothing but fresh water...and after you drain the radiator for the last time, that is when you will add coolant....This will leave 100% pure water in your engine block, this is why you must fill the radiator with 100% concentrate coolant once you get the water to come out clear....
I think mine takes about 1 to 1.5 gallons each time I dump the radiator and refill it...Distilled water is cheap, buy like 8 gallons just to be safe, and just keep doing the process over until the water comes clear...then like I said, fill the radiator with straight coolant when you done!
I also use distilled water. I also drain the block before I start. For everybody with a 3800 there is a coolant sensor right by the starter you can take out to do this. Not sure about the 3400 though. I drained my dex cool out at 50000 miles and radiator was as clean as could be. No sludge or nothing. Filled it back up with dex cool and distilled water. Its also easire to get at the radiator drain plug if you take off the plastic air dam. Also to loosen the drain plug you can use I believe a T50 torx to loosen it. Not positive about that size torx though. Maybe smaller.
I crushed up 2 and added to mine....but i would think 2-3.
The last time I drained a radiator, the drain was a pet **** and so, I am lost as to what I need to be looking for, now that the air dam is removed.
Is there anyone who has a picture of where it is exactly and what it looks like?
That sure would help me in getting this done!
TIA
Bill
I am in the process of trying to flush the cooling system (03 Monte Carlo V6) and have removed the plastic air dam.
TIA
Bill
TIA
Bill
Why are you removing an air dam?
To correctly flush the system, get a kit with the inline hose inlet so you can pump water through and let the coolant and water exit the system.
This means you'll have to have a hose coming from the top of the radiator going into a drain of some sort.
To drain it, you need to pull the plug on the bottom of the radiator on the drivers side
