'87 Monte with 57,000 Miles...
Alright, My Grandad just gave me his '87 Monte Carlo SS and it only has 57,000 miles on it.
He had it re-painted all white and completely revamped the interior. The only problem I have with it is that it takes me turning the ignition on 3 times for the car to come on once it has been parked for 8 hours. Once it turns on, it runs perfect though. Any suggestions as to what it could be?? |
Sounds like you might be losing fuel pressure. I forget if the 87's have throttle body injection or carb's?
Welcome and enjoy the forum! |
Hi O`Neil, it's great to have a GrandDad like that 4-Sure...
Sounds like you need to clean or replace your ignition switch. * People carry their keys in their pockets & it picks up dirt (etc) + may people put to many things on their key rings & the weight hanging & swinging can cause damage to the switch. http://static1.apwcontent.com/includ...ges/spacer.gif If it's not the switch, it could be vapor locking :confused: Please check back on your post/thread to see what our expert member's post on your problem... Also, if you could elaborate more on your problem ? Is the engine stock ? Does it have the stock ignition ? fuel pump ? Intake/carb ? Look 4ward to seeing your 4th Gen Monte & reading all about it...Good Luck |
congrats! you have yourself a winner
Originally Posted by Space
(Post 519917)
Sounds like you need to clean or replace your ignition switch. * People carry their keys in their pockets & it picks up dirt (etc) + may people put to many things on their key rings & the weight hanging & swinging can cause damage to the switch. http://static1.apwcontent.com/includ...ges/spacer.gif If it's not the switch, it could be vapor locking :confused: Please check back on your post/thread to see what our expert member's post on your problem... Also, if you could elaborate more on your problem ? Is the engine stock ? Does it have the stock ignition ? fuel pump ? Intake/carb ? Look 4ward to seeing your 4th Gen Monte & reading all about it...Good Luck I made a video of what it does every time I start it (after 8 hours)... |
Your video is private so it can't be viewed...
Just curious MCF staff...why would well documented (with pictures) how-to threads be rejected and moved to general sections (or disappear all together) but a question about a car not starting be approved for the how-to section? :confused: |
Originally Posted by 03SSLE
(Post 520155)
It is important - especially in colder weather - that the choke be properly adjusted. To start a cold engine that utilizes a carb you need to depress the gas pedal once prior to cranking the engine. This sets the choke and restricts air flow so the engine will receive a richer mixture and start. Once it starts the choke should open as the engine warms. If your engine won't start using the above procedure examine the choke. Make sure all linkage is clean and moves freely. A slight adjustment of the choke may also be required.
Check the fuel filter, If it sits a bunch there may be a ton of debris inside of the lines. another thing is to make sure the electric choke hasnt gone bad and make sure you pump the gas once or twice before you start it and let us know how your making out.
Rob@dixiemontecarlodepot |
It might be your fuel pump getting ready to crap out too
