2004 SS speedometer
Old Aug 24, 2005 | 12:53 AM
LedZep1958's Avatar
Default 2004 SS speedometer
Help! My speedometer cable (just out of warranty, $%^#) decides where home position is. At sometimes it will start at 0, sometimes at 50, sometimes at 120, it is not reliable at all. Does anyone have any suggestions on where or how to start troubleshooting this.
Old Aug 24, 2005 | 04:31 AM
mickey's Avatar
Default RE: 2004 SS speedometer
honestly I would call the Dealer and talk withthem abotu it they might replce it if you bitch enough considering it is a 04 and it is not to far out of warenty.
Other wise replce the cabel your self would be about the only thing you can do on it or hope tha the speedo it's self is not the issue.
Old Aug 29, 2005 | 02:30 AM
Zach's Avatar
I just recently had my speedometer do the same thing yours is doing. I took it to the dealer, and they replaced the "Panel Cluster". That's most likely the problem.
Old Aug 29, 2005 | 11:11 PM
montejass's Avatar
I just snaped to this, there is not a cable other than an electrical cable. It would def be either the cluster or a PCM issue I would think as well... Zach, was your's under warranty?
Old Aug 30, 2005 | 04:57 AM
mickey's Avatar
he he ther eused to bein the old ones LOL damed eletrical crap .
the worse part is after you say that i should know this i just did my guages not to long ago LOL
Speaking of witch did you ever get yours done? and what do they look like HMMMM??
Old Aug 30, 2005 | 04:04 PM
montejass's Avatar
ORIGINAL: mickey
LMAO.... Those were my thoughts as well. Man, the air over there must be realllllly thin...lol
J/K......
I did get my gauges done and really need to get that DIY finished. I started to put one together and got side tracked. I need to get it done this weekend...
Old Aug 30, 2005 | 04:11 PM
mickey's Avatar
yeah yeah i dont see ya gettign it done till next year. LOL
Old Aug 31, 2005 | 08:59 PM
chevy_jj's Avatar
it the cluster take it to the dealer and they can do a sweep test on the cluster. the cluster is all motors that run the gauges. not fix just replace. id complain, they will cover it under warranty. tell them to call the rep.
Old Aug 31, 2005 | 11:52 PM
04MonteLS's Avatar
ORIGINAL: chevy_jj
I'm having a super hard time understand what you're trying to say.
Old Sep 1, 2005 | 12:08 AM
montejass's Avatar
In short, I think he is saying it's an R&R item that can not be fixed with the cluster assembly....
Sounds as if it may be a known issue...
