'05 LT weird rattle from under the car.
I've been noticing a tinny sounding rattle when I get the rpms just right, or if i punch the gas and let off quick, any Ideas on what could be rattling on the bottom of the car? I kinda want a place to start looking when I jack it up tonight.
RE: '05 LT weird rattle from under the car.
Hi Brian,
Please record and post the sound
Does it sound like a metal to metal sound ?
Could be a exhaust metal shield ?
How many miles on your LT ?
Will it make the sound when you are in park
and rev the engine ?
I would check the exhaust and before you jack it up
and crawl under the car, I would have someone
in the car and lay next to the car and listen to pinpoint
a area to check.
Please try to post a better description of the sounds
that you are hearing.
Good Luck from
`Space
It does do it at idle too, my guess would be something exhaust related. could be a good excuse for a custom exhaust Will get a sound clip when I get home (tried recording it on me cell at lunch but it was garbled) what components are down there that could cause the noise? I'm thinking a hanger or something along those lines.
[align=center]Hi Brian,[/align][align=center]Most likely it is exhaust related,[/align][align=center]but it could be a body brace, or if it is[/align][align=center]coming from the engine compartment it could[/align][align=center]be one of the attachments to your engine.[/align][align=center]Good Luck[/align][align=center]Below are a few links on Exhaust[/align][align=center]
Dynomax Exhaust System[/align]
"DYNOMAX SUPER TURBO DUAL EXHAUST SYSTEM, CHROME TIPS Follows The OE Routing And Attaches Directly To OE Mounting Locations, Comes With Direct Fit Super Turbo Muffler That Features Exclusive Patented Flow Directors To Channel Exhaust Flow For Maximum Power, Includes Aluminized Mandrel Bent Pipes For Smooth Exhaust Flow, Comes With Required Clamps And Hangers
[align=center][/align]"DYNOMAX SUPER TURBO DUAL EXHAUST SYSTEM, CHROME TIPS Follows The OE Routing And Attaches Directly To OE Mounting Locations, Comes With Direct Fit Super Turbo Muffler That Features Exclusive Patented Flow Directors To Channel Exhaust Flow For Maximum Power, Includes Aluminized Mandrel Bent Pipes For Smooth Exhaust Flow, Comes With Required Clamps And Hangers
[align=center][/align][align=center][/align][align=center]http://www.autopartswarehouse.com/sh...nte_carlo.html[/align][align=center][/align][align=center]______________________________________[/align][align=center][:-][/align][align=center]http://www.car-stuff.com/mmparts/che...o/muffler.html[/align]
