2003 3.8 Coolant Leak HELP!!!!!!
Old Nov 14, 2010 | 11:05 AM
rperry92109's Avatar
Default 2003 3.8 Coolant Leak HELP!!!!!!
I have a severe coolant leak which appears to be coming from behind the harmonic balancer (damper). Coolant comes out almost as fast as it goes in. It's not the by-pass L's or the water pump. Could the water pump housing have a hole in it?
Old Nov 15, 2010 | 07:11 PM
wnmech's Avatar
Have you checked the weep hole that is on the water pump underneath the pully? If a water pump is going to fail it will port water out of that hole.
Old Nov 15, 2010 | 07:18 PM
nitehawkjcb's Avatar
It could very well be the water pump/gasket
Old Nov 18, 2010 | 02:17 PM
Milhouse's Avatar
Could be, could be alot of things though.
Old Nov 22, 2010 | 11:47 PM
c'mon get this a-hole out of here Mods...... spammer from the same a-hole......
Kevinpak
Feb 2, 2013 10:15 AM
qcakartracer
Nov 23, 2012 08:31 AM
Mac7504
Aug 17, 2011 09:43 PM
Vladimir
Nov 3, 2009 12:08 PM
