2002 monte carlo SS, no power, wont go over 20 mph.
Old 07-19-2018, 12:28 AM
Jasonwilburn98's Avatar
Default 2002 monte carlo SS, no power, wont go over 20 mph.
Hi guys,
. Just got this car. 3.8, 109,000. Previous owner said it wont go over 20 mph, which it doesnt, I tried. Before I get crazy on this I figured I'd ask for some direction first. Where should I start?? I am picking up a fuel pressure gauge today after work. Also, I have no check engine lights.
I am replacing the BCM also as I have a mystery battery drain. Thank in advance
Old 07-19-2018, 05:19 AM
First place I would check is the catalyst convertor. Does the exhaust sound weird like it restrictive ? Can put your hand over the tailpipe and see if there is normal flow when you rev the engine. Good luck
Old 07-20-2018, 11:21 PM
I'll add, can you look under the car, does the cat get red in color?
GooberMT
03-07-2017 03:46 PM
William Harper
12-21-2016 05:52 PM
zombi86
02-03-2013 10:34 AM
Maroon SS
12-10-2012 07:39 PM
montego
12-03-2009 07:16 PM
Quick Reply: 2002 monte carlo SS, no power, wont go over 20 mph.
