2004 Dale Jr SS Supercharged
Old 03-16-2011, 06:39 AM
kolakoff's Avatar
Unhappy 2004 Dale Jr SS Supercharged
Recently I replaced my multi function switch to fix my headlights. No problem, everything seemed to work fine. Got up this morning to go to work and no headlights. I have tail lights and running lights. I have to hold the lever back on the dimmer switch in order to keep high beams on and I have no low beam at all. Anybody ever have this problem?
Old 03-16-2011, 06:53 AM
Sorry 2 read about your problem Sounds like a short in the switch or the dimmer switch is bad...Check connections, clean. Also go to our Search Engine & Type in headlight problem and it will reveal several threads/posts on this subject.
Also check back to see what our expert tech member's post on your problem....Good Luck 4-Sure...
Search Forums
Show Threads Show Posts
Tag SearchAdvanced Search
Old 03-21-2011, 06:20 PM
i have a similar issue with my dale jr edition... if i turn my highs on all my lights shut off except my fogs and i have to hit the switch a million times for them to come back on. I had the switch replaced and they told me the problem was fixed and ive had it happen to me since then so i have no idea what is going on.
Old 03-21-2011, 08:03 PM
The dimmer switch on my Dale Jr is flaky. A lot of times when I go to use it, I have to pull it back a few times before it will finally click on and the same thing when I go to shut the high beams off. I figure the turn signal lever will have to be replaced soon.
Bambi, do you remember how much it cost to have it replaced?
Wayne
Old 03-21-2011, 08:09 PM
my dad had it replaced for me... i was in high school at the time... 5 years ago so i dont remember how much it was
Old 03-21-2011, 08:14 PM
Ok, thanks.
Wayne
Old 03-22-2011, 08:01 AM
kolakoff's Avatar
Well, I've replaced my dimmer switch at great expense and I am getting tired of messing with it. A nice blue neon single pole double throw switch, and an inline fuse and some thhn 12/2 wire will take care of it. I will take it completely off the system and wire it old school, problem solved.
86_monte_SS
12-05-2012 04:14 PM
Kutschkey
09-01-2008 09:17 AM
Quick Reply: 2004 Dale Jr SS Supercharged
