1980 Monte Carlos cranks but wont start
Good morning all,
I'm the proud owner of a 1980 MC T-Top, but I need the some help. I live in Cali and as you guys know we need to smog our MC, I took my MC to get it smog and didn't pass the test. I started changing some basic stuff, like spark plugs, wire, oil change, distributor cap and the EGR. Well I took it back to re-test and the problem was there still. The problem is the EGR passage in the intake manifold is clogged. What I did bought some carb cleaner removed the EGR spray the opening poke the passages with a wire, removed the carburetor. When I assemble everything back to start the car actually It did start then after a minute i turn it of when I try to start the card back again that is when I encounter the problem. the car just cranks but wont start I have no idea what I did or move, If anyone can give me some advise on what to check or move to make it start again it would be really https://cimg8.ibsrv.net/gimg/monteca...0bfee0153c.jpg nice. |
Originally Posted by ramy73
(Post 715761)
Good morning all,
I'm the proud owner of a 1980 MC T-Top, but I need the some help. I live in Cali and as you guys know we need to smog our MC, I took my MC to get it smog and didn't pass the test. I started changing some basic stuff, like spark plugs, wire, oil change, distributor cap and the EGR. Well I took it back to re-test and the problem was there still. The problem is the EGR passage in the intake manifold is clogged. What I did bought some carb cleaner removed the EGR spray the opening poke the passages with a wire, removed the carburetor. When I assemble everything back to start the car actually It did start then after a minute i turn it of when I try to start the card back again that is when I encounter the problem. the car just cranks but wont start I have no idea what I did or move, If anyone can give me some advise on what to check or move to make it start again it would be really https://cimg8.ibsrv.net/gimg/monteca...0bfee0153c.jpg nice. I am trying to recall from over 47 years back at this. I will do a little research and see if there could be something else. Good luck. |
Thank for the advice. I will check tomorrow for those points to see if I miss something
