06 Throttle body problems
I have a 2006 with the 3.5. I took off the throttle body, cleaned it, and reinstalled it only to find a "Engine Power Reduced" message pop up. I tried taking it back off and putting it on again, I checked the connection for the throttle position sensor, and disconnected the battery. Nothing has worked. I can start the car, but it is such a rough idle and will not accelerate. Any suggestions?
Is the TPS (Throttle position sensor) plugged in correctly?
Could also need a cleaning and relubricated. Try un plugging the MAF (For test purposes) and see if it idles/runs any better. Check all the vacuum lines for leaks... are they connected properly? If it ran properly before disassembly.. makes sense it should run after re assembly.. if re assembled properly/correctly. |
Like stumpi said if it is all back together the way it was and there no bent or damaged pins in the electrical connectors... then try the re-learn required on the newer systems.
First set the park brake and turn all accessories off. next turn the key to ON, engine off next slowly press the gas pedal all the way down and release three times slowly in 1 min. next turn the key to the off position. next turn the key to ON, engine off next rapidly press the gas pedal to the floor ( not through it) and release rapidly next turn the key off... wait 1 minute now follow this: IDLE RE-LEARN Follow thes easy instructions for a required idle re-learn: Required following: Battery boost/ re-charge, Battery replacement, Induction system maintenance. - Turn off all power accessories - Start engine and allow to Idle for 2 minuites - Turn on as many power accessories as possible and continue to Idle for 2 more minuites - Apply and hold the brake pedal down and place gear selector in any gear, remain Idle for 2 more minuites - Return to park , release brake pedal, turn off power accessories. - Re-learn completed |
I tried the relearn and it did get slightly better, but still not fixed. I tried starting the engine a few more times and I was able to control the rpm's with the gas pedal, but when I let it idle it still jumped and shook.
Because you disconnected the battery you have lost all the learned values/ parameters.
Go for a normal drive let it re-learn, if you are up to it here is a condensed version of a driving cycle. [font=]General Motors Driving Cycle[/font] A complete driving cycle should perform diagnostics on all systems. A complete driving cycle can be done in under fifteen minutes. To perform an OBDII Driving cycle do the following:
Reprinted on OBDII web site courtesy of General Motors Corporation© General Motors Corporation |
Nothing has worked. Thanks for the suggestions. I am just going to take it to the shop and see what they can do with it.
