06 SS tail light and parking light out driver side
ok i have the 06 SS and i have the projector headlights and today for some reason the halo went out but everything else worked then i heard a fuse pop and the parking lights went out along with my tail light but only on my driver side is it just a fuse or something more...thanks for the help
the parking lights should be fused individually side to side but with non factory projectors it might just blow again depending on how they are wired in. if you up the fuse rating by 5 amps (example was 15A replace with 20A) it should be okay.*
*that is only my suggestion and its not always a good idea to increase the fuse rating. it could cause a wiring problem on that circuit from the wire not being a heavy enough gauge. |
| All times are GMT -5. The time now is 03:12 AM. |
