02,ss-low coolant level message
Old Feb 4, 2007 | 01:08 AM
schultzy's Avatar
Default 02,ss-low coolant level message
low coolant level came on about 5 weeks ago, added coolant, plus some, message stays on!!I suspect that sensor needs to be replaced. where in the *&%$%$@* is it!! or is there some sort of way to reset it? help!@
Old Feb 4, 2007 | 10:02 AM
mickey's Avatar
Default RE: 02,ss-low coolant level message
most of the time those are on the rad. in the top side of them somplace and or they are on the coolant bottel twords the bottom. I have also seen them in the bototm facing up.
Old Feb 4, 2007 | 01:52 PM
InTheIROC's Avatar
I had the same problem with my 01 SS, the sensor went bad. It is on the passenger side of the radiator, at the top.
Old Feb 5, 2007 | 02:47 PM
golfstud2k4's Avatar
yeah, the sensor is on the radiator, on my 01 ss it is on the side of the radiator,down towards the bottom, you have to pull the radiator to replace it... Its a square plastic box(mineis grey)that is about 2"x3". Costs about 35-40$
Old Feb 5, 2007 | 09:13 PM
2000LS's Avatar
woah, pull the radiator? its on the passenger side, part way down on the back of the radiator, as i recall i pull out the battery to gain access on the w bodies.
now 'sometimes' i've seen it work to clean the sensor, if your coolant has been low anytime recently at all they can get covered with that mud/gunk/crap that dex-cool turns into and thats why it thinks its low, obviously not the case if you remove it and its clean. other times the sensor/module is just bad so...
if time is worth more than money to ya, i'd just put a new sensor in, if ya have no money and all the time in the world, try cleaning first, but you may end up just replacing it anyway.
Old Feb 5, 2007 | 09:19 PM
InTheIROC's Avatar
You don't have to pull the radiator, just the battery. If you have small hands, you might be able to get it out without pulling the battery.
Skurpio
Aug 24, 2022 07:29 PM
TMoney
Aug 18, 2013 02:37 PM
Danariel
Nov 26, 2010 10:21 PM
joesumrall
Oct 26, 2007 08:35 PM
turner_dtp
May 7, 2007 03:32 AM
