01 SS bizarre electrical issues
Old Jul 16, 2013 | 07:27 PM
blkvpr's Avatar
Default 01 SS bizarre electrical issues
So a couple days ago I bought an 01 SS (not supercharged) as I couldn't find anything when researching to suggest they are electrical nightmares, but now it seems that's exactly what they are.
Today, once while parked while running and the a/c on, once while driving, and once when I started the car to go somwhere:
-Gauge cluster failed, all gauges set to 0/empty except for the volt gage, which was where it should be.
-a/c compressor shut off
-overhead display read only --
-radio says CAL error
-all of the above happens simultaneously
-car continues to run and drive seemingly normal
The first 2 times I was able to "fix" the problem by shutting the car off, removing the key, turning it back to "on" (not necessarily starting) and repeating a few times until everything came back. This last time that didn't help. The car stil starts and drives.
I can find nothing that sounds anything like this issue. So, what's the damage? Did I just buy a junk car?
03SSLE
May 15, 2012 11:27 AM
ExplosiveSoundz
Dec 23, 2007 07:47 AM
86montecarloooSS
Aug 16, 2006 03:50 PM
jsteezy129
Nov 15, 2005 10:47 PM
jsteezy129
Nov 15, 2005 10:14 PM
