Windshield wiper not working (passenger side only)
Well that is odd really. Seeing there is only 1 motor for the wipers. So there must be an issue with your Arm for that side. It could be binding or broken. I guess it also could be that splines that the wiper sits on is bad or if it isn't one like that but has a screw that holds it on
At the base of the wiper arm is a black cap covering a nut. Pop the cap off (may need a small flat head screw driver) and ensure the nut is tight. If it's not tight, the wiper is probably moving just enough until the weight of the arm cannot handle it.
It's an easy, fist place to check.
