Windshield washer pump fuse location?
My son has an 07 Mont Carlo that has a non functioning pump.
I was trying to figure out where the fuse may be located if there is one. He has no manuals to go by and I figured to find that first before replacing the pump. Also will check hoses after but don't see leaks. It's just not making any noise. Thanks! |
I looked for location in my Haynes Repair Manual.
In the underhood fuse block, there is a 25 amp fuse for wipers. There is a wiper low relay, wiper high relay and a washer replay. Washer relay is what you want to check. |
Thanks TomF1066!
I actually found the fuse labeled "WSW" under hood and replaced it since it was blown. Windshield washer sprayer now working! |
