MCF Website Problems & Issues This area is for problems or suggestions relating specifically to the MCF site, not the car.
Electrical??? Or other
Old 11-05-2018, 09:21 PM
JustMeB's Avatar
Default Electrical??? Or other
2003 LS, 3.4L
I recently purchased this car and I'm having a hard time finding out how to fix my problem. Car starts and runs like should but I have 2 warnings lights that stay on, "battery"(red) an "security"(yellow) and occasionally "service vehicle soon" comes on too but usually it goes off after restarting car. My high beams works fine but the indicator light may or may not. Climate control fan switch works on 5 only, can not switch from recirculate to fresh air. And the radio connector does not have power on the (red) switched 12v wire causing radio to have to be manually turned on/off. I have replaced BCM, checked and replaced fuses, relays, new battery, alternator tested good, ignition switch, and I'm currently checking all ground wires(that I can find) for good connections. Any other suggestions on what else to check???
efaz43
10-14-2016 07:00 PM
WTony
10-03-2015 04:49 PM
nicholas.swanson508
09-23-2015 10:03 PM
ra13po
08-31-2013 08:53 PM
bobobeware
12-18-2009 03:12 PM
Quick Reply: Electrical??? Or other
