Wire harness
Does anyone know the actual price of the wire harness for an 06 MCLT b/c i call different places and I've heard prices range from 25.00 to 200.00 and I know there is something wrong...
RE: Wire harness
Wire harness for what??
RE: Wire harness
For the stereo it is 125 thats what I paid for mine for my 07
RE: Wire harness
Are you asking for a adapter harness or complete dash radio one?
Adapter should be no more than $20 to adapt any radio to the GM harness. |
RE: Wire harness
ORIGINAL: JD87SS Are you asking for a adapter harness or complete dash radio one? Adapter should be no more than $20 to adapt any radio to the GM harness. You will need to check and see if you have a factory amp under your rear deck. I will assume you know where the rear deck is. If you do you will need a GMOS-LAN-02 adapter. This will allow you to keep onstar and door chimes etc. This one runs about $150. If you dont have the the factory amp then you will need a GMOS-LAN-01 adapter. It does the same thing allows you to keep onstar and door chimes etc. This kit is about $130. I know you can get either of those adapters half off if you order your reciever that is atleast $129+ from crutchfield. |
RE: Wire harness
ORIGINAL: jason2982 ORIGINAL: JD87SS Are you asking for a adapter harness or complete dash radio one? Adapter should be no more than $20 to adapt any radio to the GM harness. You will need to check and see if you have a factory amp under your rear deck. I will assume you know where the rear deck is. If you do you will need a GMOS-LAN-02 adapter. This will allow you to keep onstar and door chimes etc. This one runs about $150. If you dont have the the factory amp then you will need a GMOS-LAN-01 adapter. It does the same thing allows you to keep onstar and door chimes etc. This kit is about $130. I know you can get either of those adapters half off if you order your reciever that is atleast $129+ from crutchfield. I had a 07 Cobalt, no frills and it just used a $15 adapter, same for the kids 05 S10 Blazer. I forgot the radios in these have functions beyond the just radio control. That does suck!!! |
RE: Wire harness
yeah onstar,door chimes, and the warning chimes are run over the stock deck. Is it GMOS LAN 01 or 02 he needs? My 07 took 01.
RE: Wire harness
ORIGINAL: bonang yeah onstar,door chimes, and the warning chimes are run over the stock deck. Is it GMOS LAN 01 or 02 he needs? My 07 took 01. |
RE: Wire harness
Also steering wheel controls if you have those. Get exact part numbers and then check on amazon. You can find them for a fraction of the price.
RE: Wire harness
ORIGINAL: jason2982 ORIGINAL: bonang yeah onstar,door chimes, and the warning chimes are run over the stock deck. Is it GMOS LAN 01 or 02 he needs? My 07 took 01. |
| All times are GMT -5. The time now is 10:16 AM. |
