Wire harness
Old Sep 5, 2008 | 10:48 PM
1FastMonteCarloLT's Avatar
Default Wire harness
Does anyone know the actual price of the wire harness for an 06 MCLT b/c i call different places and I've heard prices range from 25.00 to 200.00 and I know there is something wrong...
Old Sep 6, 2008 | 08:58 AM
draxxis's Avatar
Default RE: Wire harness
Wire harness for what??
Old Oct 4, 2008 | 06:25 AM
bonang's Avatar
For the stereo it is 125 thats what I paid for mine for my 07
Old Oct 4, 2008 | 08:48 AM
JD87SS's Avatar
Are you asking for a adapter harness or complete dash radio one?
Adapter should be no more than $20 to adapt any radio to the GM harness.
Old Oct 4, 2008 | 11:33 AM
jason2982's Avatar
ORIGINAL: JD87SS
I miss those days when they were that cheap. Due to all the integration the radios have with the cars now it isn't as cheap to do.
You will need to check and see if you have a factory amp under your rear deck. I will assume you know where the rear deck is. If you do you will need a GMOS-LAN-02 adapter. This will allow you to keep onstar and door chimes etc. This one runs about $150.
If you dont have the the factory amp then you will need a GMOS-LAN-01 adapter. It does the same thing allows you to keep onstar and door chimes etc. This kit is about $130.
I know you can get either of those adapters half off if you order your reciever that is atleast $129+ from crutchfield.
Old Oct 4, 2008 | 02:46 PM
JD87SS's Avatar
ORIGINAL: jason2982
ORIGINAL: JD87SS
I never thought about all the new systems that were added.
I had a 07 Cobalt, no frills and it just used a $15 adapter, same for the kids 05 S10 Blazer.
I forgot the radios in these have functions beyond the just radio control.
That does suck!!!
Old Oct 4, 2008 | 03:15 PM
bonang's Avatar
yeah onstar,door chimes, and the warning chimes are run over the stock deck. Is it GMOS LAN 01 or 02 he needs? My 07 took 01.
Old Oct 5, 2008 | 02:14 AM
jason2982's Avatar
ORIGINAL: bonang
Depends on if he has the factory amp or not. The amp is located under the rear deck. Just crouch down with your trunk open and it should be attached to the rear deck between the 2 rear deck speakers. Mine is silver in color kinda plain looking. According to crutchfield it is the 02 if he has the factory amp, and 01 if he does not.
Old Oct 5, 2008 | 09:34 AM
Teacher's Avatar
Also steering wheel controls if you have those. Get exact part numbers and then check on amazon. You can find them for a fraction of the price.
Old Oct 5, 2008 | 11:06 AM
bonang's Avatar
ORIGINAL: jason2982
ORIGINAL: bonang
Ah ok thats good to know. Never thought about the amp. I dont have one witch is awesome since I have my own in the car now anyway.
