Upgrading Sound System
i think so idk really what model it is got it a year ago
ok these are what definably what im gonna go with
Clarion CZ300 Head Unit
MTX TR7512-44 Subs 2 of those
so i needa know an amp & speakers
ok a few amps i found idk if there right idk much about this stuff lol
http://www.woofersetc.com/p6610/DD26...hannel-Amp.htm
http://www.woofersetc.com/p7647/OVN1...-Amplifier.htm
http://www.woofersetc.com/p8067/GPV2...-Amplifier.htm
any of those good??
if i have to ill go with one of the mentioned above in the tread kinda wanna stay in the 200 or less area
any of those good??
wellll if it helps at all... those MTX subs are nice and they hit very well, used to have a set until i went up to the 9500, so i would recomend them. Also... All I run is profile amps and I love em! Im running 3 in the car now with no problems! there a great amp and the price is low for the power you get!
I would go with the profile mono D amp... I believe they only make one... use that to run your subs, As for front speakers.... I love my alpine type R's but MTX makes a pretty good speaker also... thats just my opinion
ok im thinking between these four:
http://www.woofersetc.com/p4868/AP10...-Amplifier.htm
idk which is the best but my discounted price puts these in a good price range for me
Definitely don't buy the Profile amp you linked to. It's not appropriate for the subs you picked. You need either 1000 watts RMS at 1 ohm or 500 watts RMS x 2 at 2 ohms. Those two wiring setups will be the cheapest to buy an amp for. The mono Profile amp you linked to is not 1000 watts RMS (less than half that actually), and more importantly it does its power at 2 ohms which is an impossible wiring setup with those subs. This is the only Profile amp I've seen that will appropriately power two of the subs you've chosen.
http://www.woofersetc.com/p4872/AP20...-Amplifier.htm
It looks gigantic though and it probably is class A/B, so I don't really think it's a good choice for you. The Crunch and Power Acoustic amps are the right type, but I don't know anything about the Crunch brand so I would be sure to find reviews before buying that. Power Acoustic has a reputation for overrating products, but I'm not sure on that amp specifically, so it might be fine.
This is the cheapest amp I can think of that I personally know is good quality, and I actually run it myself.
http://www.woofersetc.com/p6102/TXA1...-Amplifier.htm
