subs and rattling
hi i have a 7th gen monte and it was solid, as far as rattling goes. then i got a bright idea to dynomat the whole trunk and partial rear deck. it sounded great, then after about 6 months my plastic piece above the rearview mirror started to buzz. the one that has the seatbelt light on it. anyways i went to 2 different custom audio shops and they tell me they wont work on headliners so i need to fix myself. does anyone know how to take off the headliner fully or partially. it feels different then most, with a trim piece underneth. not sure if it has clips or glue holding it up. ANY HELP WOULD BE APPRECIATED.
i know i drag out some of my posts, so to shorten it up a bit... i was just wondering if anyone else had that problem. i was just going to pry it up a bit then stick some dynomat inbetween. seems like it would work, but i heard new head liners cost about 400.
Go to all all around custom car shop and ask them to do it. Taking out our headliners and fitting them back in through the door is no easy task at all, neither are lining up the sun visor bolts.
thanks i thought it was going to be hard. i will ask the dealer tommorrow its glue or clips that hold it up. if its just glue then ill bust out the spray adhesive and stretch for a while.
the little clips that hold on the sunvisors , not the pivoting ones, but the other ones, are a main part of holding up the headliner, along with the 2 screws holding on the sun visor itself. then you need to take off the door trim from the dash back and the front part will come down...
