6th Gen ('00-'05): Stock radio volume behaves weird
As I increase the volume to about 80%, the volume of the sound increases as normal. However, after about 80%, as I increase the volume, the sound decreases as if I was turning the volume down. Basically this makes it impossible for me to turn the volume up all the way. What could be causing this? is there any way around it?
There could be a power fade from a weak ground on the radio. You may want to check out a youtube vid and see if there is anything on that subject.
