speaker upgrade
thinking about upgrading speakers in a 2006 monte, have factory stereo base unit only, i have read that the speakers are 2 ohm as I look at my speakers from the trunk they say 8 ohm on them. whats up, any help will be appreciated. can i put an 4 ohm speaker in with the factory head unit or do i need to put in a 2 ohm or another 8 ohm. not sure.....
thanks............taz |
RE: speaker upgrade
two 8ohm speakers fed in series creates a 2ohm load on the amplifier.
RE: speaker upgrade
Two eight ohms speakers feed in parallel is 4 ohms.
Sorry guys it was early and i put series thanks for clearing that up. |
RE: speaker upgrade
ORIGINAL: Billy1987 Two eight ohms speakers feed in series is 4 ohms. |
RE: speaker upgrade
can i use 4 ohm speakers or not, thats all i need to know. math i know,.....taz
RE: speaker upgrade
My car is a 2000 i changed all my speakers to 4 ohm speakers andit worked perfectly fine. But now i am running them off a 600w rockford amp.
RE: speaker upgrade
2 Speakers that are 8Ohm wired in series would be a 16ohm load.
2 Speakers that are 8Ohm wired in parallel would be a 4ohm load. |
RE: speaker upgrade
ORIGINAL: slinkeey 2 Speakers that are 8Ohm wired in series would be a 16ohm load. 2 Speakers thar are 8Ohm wired in parallel would be a 4ohm load. new to the monte here, but not new to audio. if a reliable source (manual) told you 2ohm and you see 8ohm speakers, they must not be the factory speakers! i cannot answer your original question because i cannot verify the 2ohm load requirement for your 06. however, assuming that is accurate, you would use 2 4ohm speakers wired in parallel. my 07 is stock, and i will go see what it has in a minute..it should be the same as your 06. |
RE: speaker upgrade
oops.. sorry.. my bad. :(
I was somehow thinking that the wrong direction! lol |
RE: speaker upgrade
Yeah.. I just had to correct that....R networkswere on the brain....
anyways.. If it were my carI would go ahead and use 4 Ohm speakers If I was happy with the sound. Here is my reasoning. If the headunit can handle thedemand of the stock2Ohm load I am sure it would do fine with 4Ohms.. 2Ohm Stock> 4Ohm Replacement (Personally I would do it) I wouldn't go the other way around though. Well I would if I didn'tmind knowing thatI might burn outthe aplifier stage in my headunit.. 8Ohm Stock > 4Ohm Replacement (I wouldn't do it.... Ot I would do it if I was willing to deal with any problems) That is one man's opinion though.. Take it with a grain of salt... Jeff |
