single din head unit
i am think of getting a single din head unit with video.
one i found http://www.crutchfield.com/App/Produ...D310&tp=75 any other recommendations? |
RE: single din head unit
Can't go wrong with Alpine, get it, but make sure you get the adapter so you can watch it without having the e-brake on
ORIGINAL: 06MCLTZ Can't go wrong with Alpine, get it, but make sure you get the adapter so you can watch it without having the e-brake on im pretty sure you can rewire it so you dont need the adapter... |
with the flip out screens in our gen it will cover the heater vents.......
and if it does cover the heater vents then....??? yeah you don't need an adapter i wired in a Dual flip out. its a one wire coming out that needs to be hooked up to the negetive of your e-brake. but hooking it up to any negative with a switch in the line works too.
