-   Interior/Audio/Visual Electronics (https://montecarloforum.com/forum/interior-audio-visual-electronics-11/)
-   -   6th Gen ('00-'05): Rearview Mirror problem (https://montecarloforum.com/forum/interior-audio-visual-electronics-11/rearview-mirror-problem-36871/)
jch81 Jun 4, 2012 09:54 PM
I have an 04 ls that has a rear view mirror problem. It has the dimmer built into the mirror that makes headlights behind you not as bright. For some reason it will not stay on when it is supposed to be on. You can move the wires connected to the mirror to make it come back on so I assume some of the wires are loose. What would be the best way to tighten the wires up so that feature will work on a more consistent basis?
Thanks in advance
(I do not have onstar in this mirror if it matters)
ChibiBlackSheep Jun 5, 2012 09:22 AM
You might have to buy a new harness and splice it in
jch81 Jun 12, 2012 09:17 PM
Well I may have to look into this more now. The dimmer is completely non functional. The reading lamps still work but the little green light will not come on at all. And it is definitely not dimming anymore.
Mr Grizzly Mint Jun 12, 2012 10:25 PM
Take off the star screw and remove your mirror. Check the connection. Might be loose if it is tight than no idea how to fix it. Be careful tho I ripped a hole out off my windshield messing with my mirror.
jch81 Jun 13, 2012 12:09 PM
alright thanks ill try that and try to be careful. Definitely hope it is an easy fix. Now that you mention it I did have my windshield replaced not to long ago so it definitely could be a loose connection
