Rear Deck Removal?
I didnt see it on the how-to's but i dont know how to get that rear deck off, i got the 4 10mm bolts out, and got the 3 push pin things out, but i cant pull the sides of the seat up allong with the black thing that goes across, it feels like it will break if i pull it harder, so i cant quite get the sides of the seats back or get the deck cover off.
im trying to remove the rear speakers to use the holes as ports. |
Mitch I"m staring at mine sittin on the cave floor...I believe I just pulled however I also had all the side panels off. I do know I had it out once without the side panels....someone may have a concrete answer
alright lol you know what i mean tho? the side cushions on the seats that stay there when theyre folded down
Front what Ive done.
1. fold both sides of rear seats down. 2. take out the 4 bolts that hold the plastic thing on 3. behind the plastic thing pull out the 3 pin things I believe thats what you have done.. 4. pull the middle seat belt out of the rear deck lid 5. and then I believe you can remove the rear deck 6. Pull the rear deck straight out Reverse the steps to put back in. |
Maybe this helps? Is this what you need? I think this guy may have taken too much out tho...
https://montecarloforum.com/forum/sh...ear+generation Lisa |
so those side things should come all the way down?
Did that link I posted with the pics help you?
Lisa |
yeah kinda but he took the whole seat out =p, im kinda worried about being able to get it back on i guess
I don't think it is necessary. I can't find the other thread that had how to's for it. I should have written it down because I need to put my rear kickers in.
The side pillars for the seat do not have to come out..I do know that. Once its unbolted and pins are out. Pull it forward enough to be able to pull out the rear deck
Make sure to pull the rear deck straight out |
