pioneer avic decks fitting in this car
eviling, i think the most problem that people have with installs, and i did also, is it fitting in the depth space that is given. with my current dash, Kenwood KDC-MP638U, i had to cut some of the plastic out in the rear of where the dash goes.
Other than that, all double din and single din receivers should fit fine in the provided space as far as i know.
its all inside the dash, you wont see it when installed. what your cutting is directly behind the headunit.
just make sure if you do this that you vacuum it good because little plastic pieces will be all over
And yeah, with the right mounting kit, most headunits fit good and look great in our dashes
