Need some help - LED color change inside the Deuce
I am changing out the LED lights color in the Deuce from blue to red.
There is a blue stretchy color sleeve on the led lights in the window and door lock controls. I want to replace the blue sleeve with a red one. The LEDs are soldered in so just replacing the colored sleeve is the easiest route to take. I just can not find any color sleeves that small on the internet. If you can find a site that has em I would sure appreciate that. Thanks! (Man I like the Google Chrome) |
(Post 416783)
There is a blue stretchy color sleeve on the led lights in the window and door lock controls. I want to replace the blue sleeve with a red one. The LEDs are soldered in so just replacing the colored sleeve is the easiest route to take. I just can not find any color sleeves that small on the internet. If you can find a site that has em I would sure appreciate that. Thanks! (Man I like the Google Chrome) as for the sleeves, you may want to look in grand prixs, they all have red interior lighting, or else you can get some sort of transparent vinyl that is red and that should help you out. should be similar to this, check it out: https://montecarloforum.com/forum/si...me-pics-25376/ |
Thanks!
Tadd what about Gel Sheets. You can get them by the sheet at any music store. I know that Lansing has a Guitar Center, you could check there. or this web site.
130: Color Gels |
