Nav ???
Will the nav from a grand prix or some other GM car/truck work in the monte? just a plug and play in the double din hole???
RE: Nav ???
yes if it is a GMLAN nav that is in a few 2006 car and most 2007's new computers isn't that great got to love gm
RE: Nav ???
If it's a universal like you suggested and plugs directly into the din I can't imagine why it wouldn't work.
RE: Nav ???
i was thinking someting that would plug right into the stock wire harness and work..
RE: Nav ???
the 06 mc is a gmlan plug and 05 & older have a class-ll data bus plug there not the same. The same things don't go through the raidio it has to be a gmlan radio
gmlan Compatible vehicles are: 2006 Monte Carlo, Impala; 2007 Avalanche, Suburban, Tahoe, Monte Carlo, Impala and Yukon. |
RE: Nav ???
ORIGINAL: rrobert05 the 06 mc is a gmlan plug and 05 & older have a class-ll data bus plug there not the same. The same things don't go through the raidio it has to be a gmlan radio gmlan Compatible vehicles are: 2006 Monte Carlo, Impala; 2007 Avalanche, Suburban, Tahoe, Monte Carlo, Impala and Yukon. ok.. so any NAV unit from a 06+ Impala, Avalanche, Suburban, Tahoe, Monte Carlo, and Yukon WILL work?? |
RE: Nav ???
I would say yes the radio has two square plugs on it the same size and about 10 pin's each
RE: Nav ???
well.. i would do the same thing as i did with my Dodge Ram 1500 Rumble Bee. . get the NAV on eBay. and sell the old head unit after i get the NAV installed.. so how can i be 100% sure??
RE: Nav ???
RE: Nav ???
nope this is the back of your radio and if you have a factory amp, bose it has to be for it
[IMG]local://upfiles/1196/00A933DA17464B6CB500D6BE69D22E1B.jpg[/IMG] |
| All times are GMT -5. The time now is 05:50 AM. |
