Nav ???
Old Oct 3, 2006 | 05:46 PM
TonyRumbleSS's Avatar
Default Nav ???
Will the nav from a grand prix or some other GM car/truck work in the monte? just a plug and play in the double din hole???
Old Oct 4, 2006 | 01:23 AM
rrobert05's Avatar
Default RE: Nav ???
yes if it is a GMLAN nav that is in a few 2006 car and most 2007's new computers isn't that great got to love gm
Old Oct 4, 2006 | 02:28 AM
SoCalSS's Avatar
Default RE: Nav ???
If it's a universal like you suggested and plugs directly into the din I can't imagine why it wouldn't work.
Old Oct 4, 2006 | 11:37 AM
Default RE: Nav ???
i was thinking someting that would plug right into the stock wire harness and work..
Old Oct 4, 2006 | 12:17 PM
rrobert05's Avatar
Default RE: Nav ???
the 06 mc is a gmlan plug and 05 & older have a class-ll data bus plug there not the same. The same things don't go through the raidio it has to be a gmlan radio
gmlan
Compatible vehicles are: 2006 Monte Carlo, Impala; 2007 Avalanche, Suburban, Tahoe, Monte Carlo, Impala and Yukon.
Old Oct 4, 2006 | 12:19 PM
Default RE: Nav ???
ORIGINAL: rrobert05
gmlan
ok.. so any NAV unit from a 06+ Impala, Avalanche, Suburban, Tahoe, Monte Carlo, and Yukon WILL work??
Old Oct 4, 2006 | 12:29 PM
rrobert05's Avatar
Default RE: Nav ???
I would say yes the radio has two square plugs on it the same size and about 10 pin's each
Old Oct 4, 2006 | 12:31 PM
Default RE: Nav ???
well.. i would do the same thing as i did with my Dodge Ram 1500 Rumble Bee. . get the NAV on eBay. and sell the old head unit after i get the NAV installed.. so how can i be 100% sure??
Old Oct 4, 2006 | 12:46 PM
Default RE: Nav ???
for example,
this fit ??
http://cgi.ebay.com/ebaymotors/GM-NA...33232849QQrdZ1
Old Oct 4, 2006 | 01:04 PM
rrobert05's Avatar
Default RE: Nav ???
nope this is the back of your radio and if you have a factory amp, bose it has to be for it
[IMG]local://upfiles/1196/00A933DA17464B6CB500D6BE69D22E1B.jpg[/IMG]
