Looking for a tap off for 12V in ACC/Run
I'm adding a bluetooth speakerphone to the car - it wants a 12V switched source.
I probed around and could not come up with anything that was in easy reach, wondering if anyone knows of a tap point before I start looking in other places. 2006 MC btw Thanks |
Hi have a 2001 monte ss with A auxiliary power connection [power drop] it is under the glove box and should be marked it is there so you could extra things that need power.It would be worth a look if you have a owners manual look in features and controls section it might help
good luck |
Another option is the power window relay. It's also in the fuse panel under the glove box. Good luck!
