-   Interior/Audio/Visual Electronics (https://montecarloforum.com/forum/interior-audio-visual-electronics-11/)
-   -   6th Gen ('00-'05): How do I install new speakers? (https://montecarloforum.com/forum/interior-audio-visual-electronics-11/how-do-i-install-new-speakers-58575/)
ZealousFern Jul 8, 2017 09:32 PM
I am tired of my speakers sounding bleh (probably blown by previous owner). I bought some new speakers that will be here in a couple days. They are nothing fancy or expensive. What do I need to install them? I saw some thing about a GM harness, is this something I need? If so, would I need it for the door and rear speakers? I have no idea what I am doing in that aspect.
Getting to the speakers to replace them seems difficult, but there seems to be a few guides posted here, so I shoild be able to struggle through that (I hope).
Is there anything I should know or do?
Thank you in advance :)
drivernumber3 Jul 9, 2017 06:51 AM
check out these youtube videos I found several here that may help at all locations.
https://www.google.com/?gws_rd=ssl#q...=1499600008091
wht02monte Jul 9, 2017 09:03 AM
Its easier than you think.. The hardest part is putting the door cover back on with the lifting over the clips and such.. The speaker replacement itself is simple as can be..
The_Maniac Jul 9, 2017 10:17 AM
Most factory speakers use a connector and your aftermarket speakers use blade connection. Some people cut the factory connector and solder the factory wires to new speakers.
Honestly, there is no reason to do that. Cruthfield, Amazon, Best Buy, local audio shops, sell adapters to go from the car wiring to any aftermarket speaker. Spend a few extra bucks and get the adapters. It helps keep the install clean and if you aver go to sell the car or change the speakers, it will be easy to do again.
ZealousFern Jul 9, 2017 11:29 AM
thank you all for the responses. which adapter should I buy? Is this correct, "Metra 72-4570 Speaker Harness for Select GM Vehicles"
will I need 2 pairs, one for doors and one for rear?
oldredblackie Oct 10, 2017 11:28 PM
try this...
Actually, just replace the back ones for now and see how you like it
might surprise you, back ones are easiest to replace.
