passenger side headlight hi/low beam doesnt work
Old 04-06-2010, 12:45 AM
teamfbody's Avatar
Default passenger side headlight hi/low beam doesnt work
i have a 2001 Monte my passenger side headlight doesnt work the high beam doesnt work or the low beam doesnt work i switched both the high beam & low beam bulbs and the problem is still there,but heres the funny thing the side marker light works has anyone had this proble before???
Old 04-06-2010, 09:17 AM
I was going to joke and suggest that you didn't plug the headlight back in to the car :P
But the turn signals work... fuses?
Old 04-08-2010, 10:06 PM
teamfbody's Avatar
Default passenger side hi/low beam dont work pt2
heres an example of what i meant when i said my passenger side high beam or low beam doesnt work but my marker,turn signal,hazard, park lights etc. works fine all driver side headlights signal,marker, park,hazard etc.work fine i checked both bulbs both are good i dont seem to kno what the problem is has else anyone experienced this dilemma b4???
Attached Thumbnails passenger side headlight hi/low beam doesnt work-easter-2010-075.jpg
Old 04-21-2010, 09:42 PM
I have a fix posted for my headlights out. If yours worked and progressively got worse than you may need the same fix. Multi-purpose switch replacement. But your pic sure looks more like the ground.
Good luck!!
Old 04-25-2010, 10:21 PM
teamfbody's Avatar
Good luck!!
thanks i will try the ground but after i switched the low beam bulb again all lights are on now(hi/low beam markers) but u can tell that the lights are not getting enough juice because they look dim thats in the daytime while in park,shift it to drive all lights remain on DRL's dont come on anymore but at night the driver side light shines bright and i noticed the high beam bulb lit up on the passenger side all lights are on both high/low beam but are dim
bcsfd306
01-12-2019 07:58 PM
Zod642
41
01-27-2018 09:56 PM
BlackWidowSS
12-18-2014 03:55 PM
rpkelly
07-02-2013 01:56 PM
orthokneepa
10-31-2006 09:47 AM
Quick Reply: passenger side headlight hi/low beam doesnt work
