Front Speakers
I have a 2004 Monte Carlo LS, I had an Alpine stereo put in, the front speakers sometimes go out then come back on at some later date, the speakers even make noise sometimes before I even start the car, I have had the amp changed several times, the Chevrolet dealer cant solve the problem, any help much appreciated
RE: Front Speakers
Could it be the deck?
RE: Front Speakers
No, we already tried that also, the factory radio also did it
RE: Front Speakers
If you have not already done so, I would replace all the wires to the speakers having the problem.
RE: Front Speakers
Front speakers? Isn't that where, if you leave your keys in and open the door it will give a warning sound.
RE: Front Speakers
I think that comes from under the dash, I am talking about the speakers in the doors, I am not sure that the chime comes from under the dash I just think it does
RE: Front Speakers
well for one theing the factory ding in the montes comes from the streo when the are stock and i think it is that factory amp causing you all the problem just get rid of it wire around it that alpine heade deack will give you more power and sound better anyways not sure where but i did find a link on here for wiring aound that amp on here somewhere
RE: Front Speakers
Yeah, the warning chime does come from the drivers door speakers.
RE: Front Speakers
I have just talked to the guys that put in the Alpine, that is what they said we should do, just wire around the amp, I dont need it because of the Alpine and the Alpine speakers that are in it, Thanks
| All times are GMT -5. The time now is 08:57 AM. |
