-   Interior/Audio/Visual Electronics (https://montecarloforum.com/forum/interior-audio-visual-electronics-11/)
-   -   Factory stereo issues (https://montecarloforum.com/forum/interior-audio-visual-electronics-11/factory-stereo-issues-58312/)
Dyl 05-12-2017 03:38 PM
I just bought a 06 SS.........The front two speakers are the only ones that work and its super quiet when turned all the way up.......any suggestion?
Barovelli 05-12-2017 07:41 PM
Excellent choice of automobile.
Is the amplifier present in the trunk under the shelf? Check the fuse for the amp? It's in the right kickpanel fuse block.
Dyl 05-16-2017 11:04 AM
I checked the fuse and its good.......is the amp blown?
EvanLauer 05-17-2017 12:35 AM
Not sure if this is the same issue I had, but if it is, there is an orange wire inside of a cluster of wires leading under your interior to the trunk. That orange wire provides power to the amp, so when it splits you will get nothing from it. I would try checking to see if you can find a split somewhere.
