Big Three Upgrade
dont got a pic, but its really easy for this car, i ran it from the corner of the engine , theres a bolt directly on the egine right there holding down something, than i ran that to the stock ground bolt on the tire well, and back to the battery from there.
How-To section, there is a sticky with the Big 3 Upgrade:
https://montecarloforum.com/forum/sh...ad.php?t=14369
It's always quicker/easier/safer to simply add the upgraded wires instead of replacing the existing wires. In this case, more = better.
As for where to run the wires.....
The battery is grounded to the chassis, follow the ground wire from the battery and you'll see it. That's the spot I used for the battery to chassis ground as well as the engine block to chassis ground. The other end of the block to chassis ground is connected to the bolt on the alternator bracket, you can see the head of the bolt, it's mounted vertically. The last wire goes from the hot wire on the alternator (there's only one) to the positive terminal on the battery.
Yeah so I found this:
http://www.grandprixforums.net/big-3...diy-29192.html
Pix and good information even though its on a GP.
