Big 3 upgrade
Has anybody done the "Big 3" upgrade? If you don't know what that is, you haven't done it. Reason I ask is because I am going to be doing it this weekend but I don't know where the wire at the top of the alternator is connected to on the other end.
Obviously it's in the wire loom, and obviously it's about an 8ga wire. The wire loom breaks off in two directions, to the left the loom ends at a multi-pin molex plug with many 18 or 20ga wires connected to it. To the right it goes to the airbox and then continues down to somewhere else, not to the positive terminal of the battery as I expected. The chassis to engine block wire looks easy to replace, as does the negative battery terminal to chassis, but the alt one has me stumped.
Ohy! I thought it would have just went to the battery, but when you find out, please let me know. I can however suggest a website that would help. If you goto www.the12volt.com they have a whole section just for the big 3. Check it out, someone there will know.
ORIGINAL: Gr4v3_7
I have done this on at least 50-60 vehicles locally.I have got nothing but good feedback.Its a ground and charge wire upgrade. Chassis to block, block to frame,alternator to battery +. Using 4 ga. or bigger if you want.Them little ground straps are a joke.This and an overdrive pulley usually cures any voltage sag at idle, unless you have a ton of stereo/amp draw.
ORIGINAL: benhillzone3
so what exactly is the big 3?
I'm in the process of the big 3 upgrade. Got the grounds done but also am stumped by the alternator positive that runs through loom by airbox then I believe it goes 2 the positive post of the starter motor. I believe so cuz I traced positive from battery post 2 the positive post of the starter motor. Can any1 say 4sure whether or not this wirfrom starter goes straight 2 the alternator & if.possible 2 by-pass that wire and go dirrectly from battery positive to positive bolt on the alternator. HHEELLPP MMEE PLZ. THANX
