DRuben |
02-19-2012 06:53 PM |
Amp Overheat Fix
5 Attachment(s)
I got bored today and decided to find a way to get my amp to stop overheating on my ride to and from work. About 3/4 of the way to work EVERY morning my amp cuts off (Cheap Sony Xplod 1000W) and if you touch it you would get burned... I took off the back panel (voids warranty idc :rotfl:) and put a metal grill thingy to attract the heat and cut a square in the center and put some insulation over it to keep dust from getting in the amp. I sealed every corner and loose end of the insulation with sealant. I dug around in my old electronics box and found my old original xbox, I took out the fan and attached it the the open square that I cut in the insulation and a perfect fit. I put sealant around the fan and the insulation so hold it and it is holding pefectly! I attached the ground wire from the fan to the ground contact on the amp, and the power wire from the fan to the remote contact of the amp. Every time I turn the car on the starts up just like the amplifier. The fan moves a good amount of air and I drove for 4 hours straight and no hot air was coming out of it at all!!! I feel proud of myself :). I still have some insulation left and sealant, idk what Im gonna do next :p. I used the painting tape to temporarily hold it until I went to home depot to get some longer screws to mount it...
