Amp I Might Throw In The Monte :-)
I do DB DRAG during the summer time in the minnesota area here, on occasion over in Wisconsin, I have 2 of these amps right now, use these to push a pair of 18" Quad Voice Coil 1.4 ohm MA Audio Kores
http://i1104.photobucket.com/albums/...G/IMG_0631.jpg http://i1104.photobucket.com/albums/...G/IMG_0632.jpg http://i1104.photobucket.com/albums/...G/IMG_0633.jpg http://i1104.photobucket.com/albums/...G/IMG_0634.jpg http://i1104.photobucket.com/albums/...G/IMG_0636.jpg http://i1104.photobucket.com/albums/...G/IMG_0637.jpg |
dang that thing sweet! please tell me it has dual 0 gauge inputs on it?
you can in fact run 2 runs of 0 to it they will both fit in the input :-)
good thing! hell i see 3500 watt amps with dual positive and ground in puts! id definitly run 2 1/0 gauges in to that thing. what are the specs on the beast?
however I really havent decided yet if i want to throw it in the monte, would be quite costly, for the db drags I run these in a van on daisy chained 16volt deepcycles, im going to be digging through my pics here soon, and if anyone is in my area of minnesota here, I do own a 900 spl mic so I can do readouts for people if they are curios what they are hitting.
RMS Power @ 1 Ohm, 16V - 6,500
RMS Power @ 1 Ohm, 14.4V - 5,300 460A Draw |
Very nice!!
Originally Posted by DTG
(Post 399452)
the specs are nice! kinda sucks its 6500 at 16 volts though |
yeah and no, its not really a everyday kinda amp, its really more for db drag which more often then not people are running 16v, you start getting over 148 dbs and 16volt is pretty much where its at to get over that 150-160 area
I just had a good idea for the monte trunk tonight to btw, not sure if its been discussed anywhere yet, but im thinking about using peel and seal to line the trunk with and then going over the peel and seal with a coat of rhino line, thoughts on that?
