which amp to buy?!
This diagram shows 2 4-ohm subs wired to a 2-ohm load. Does that change the RMS rating on the sub? http://a248.e.akamai.net/pix.crutchf...4-ohm_mono.jpg
That's a good idea! Thanks! Also, I'm so happy I found this amp because it's cheaper than the MRP-M1000 and it pushes more to the subs. What do you guys think of it for the subs I ordered? Here it is: Hifonics HFi1000.1D (HFi 1000D) Class D Monoblock Car Amplifier
Thank you!
Thank you!
Thank you!
Thank you!
I have the Rockford Fosgate Prime R500-1 powering two Pioneer 12's and it works great. I've always been satisfied with Rockford Fosgate amps and have never had any issues. I have heard good things about Hifonic amps as well. They are priced good too.
Just make sure the amp and subs are 2ohm stable, some companies don't have accurate rms ratings like sony explodes, I haven't heard much of hifonics, but I'm a proud owner of 1000rms alpine amp. Also you may wanna buy a 1farad or bigger capacitor. When it comes time to hooking it up post back for guidance on the settings.
Hey guys! Finally found an amp! I was just wondering if it's possible to hook the amp up to a switch so when my parents, or more sensitive friends ride in the car I can shut them off? Would I just put the switch in the turn on lead wire?
Also, might be a newbie question, but on my sub, there's two terminals and they push up and come down. Do I push this up, stick the wire in, then let it down to hook them up inside the box?
Thanks!
Tyler
Thanks!
Tyler
Thanks!
Tyler
Thanks!
Tyler
and release and it holds the wire.
