Aftermarket Replacement Amp
Ok I now know the factory amp in the trunk has gone bad in my 01 Monte Carlo. I have been unable to locate a used factory one. Can I use an aftermarket one? If so, how do I install it with my factory radio.
RE: Aftermarket Replacement Amp
http://us.st12.yimg.com/us.st.yimg.c..._2006_34651499 This is a TMA amplifier. you can see the small "plugs" on the amp. They are Line level inputs that you can just draw from your signal input going into the stock amplifer. They are marked "High Level Input" |
http://cgi.ebay.com/2004-CHEVY-MONTE...QQcmdZViewItemthis is a better route
| All times are GMT -5. The time now is 09:32 AM. |
