6th Gen ('00-'05): 2004 XM radio for factory system
Does anyone have XM satellite radio in a 2004 car? Looking at my owners manual it lists this as an option but my car does not have it. Just trying to find out what would be needed to upgrade my stock radio for this. I have the AM/FM - Cd-Cassette radio. From doing a search on eBay it looks like there is a separate module for the XM. So I'm thinking I would need to get that and a couple of harnesses and probably the shark tooth antenna...
Has anyone done this?
Thanks
Thanks
XM was an option for 2004. Such as mine did not come with XM, but others did. I added XM to my 04, but did not install the antenna as I only needed it for another change I was up to.
Here is a complete write up on what I did and learned about the process:
https://montecarloforum.com/forum/fw...g-heavy-58519/
thanks
Dave
Included in that thread is an excel file. That file has the part number you need for the proper xm receiver. It comes with montes, impalas and a couple other cars. That is the best thing for you to get since you want xm to work (a correct part number).
As for wiring, depends what you want to do. I wanted wiring from a monte/impala so o had the correct length (and because I changed routing, I had to shorten it). Read my thread, I talk a bit about wiring.
To test if the xm receiver will work with your factory radio, you can test with the diagnostic port under the dash. I took a scrap xm receiver harness, using the orb-ii diag port under the dash, connected the harness to it. You only need power, ground and data connections. To connect to the individual pins on the diag port, I used paper clips (wrapped the individual wires around the paper clip and used electrical tape to cover part of the clips so no accidental contact). Once connected, start the car. If your radio is compatible with xm, cycle the bands and xm should show (might say xm lock). If so you are good.
I would recommend you send the xm receiver out to be unlocked (a gm tech-ii cannot unlock it, been there/done that). You can remove a chip like I did, but I read it will not retain xm presets if you do.
That is the quick and short. Read that thread I gave, as that has a ton of info that will answer probably most of your questions.
One other note I remembered. If you do a test with a xm receiver via the diagnostic port and the radio does not see it, you may just need a different radio. If you say factory, I have the part number to the radio I am using in my monte in the spreadsheet on my other thread about the xm stuff.
I have been told after what I learned on the subject ppl should get college credits listening to the full scope of what I learned lol
No problem Jason posted a photo of one off of the car so hopefully I will be able to find one...
